Auto CAD 2021 - Auto Publish to different directory
Hello dear Auto CAD world 🙂
I was looking for hours in forums but could not find any fitting answer to my problem.
Is it possible to "Auto Publish to PDF" to a different Hard Disk while the whole directory-structure of the .dwg-workspace is considerd?
Example:
Workspace for CAD-User: << x:/CAD/ >>
In this workspace are the dwg-files organized in project-structure.
Example:
<< x:/CAD/project_1/part_a/xyz.dwg >>
The need is a automated workflow to "auto publish on saving" to the marketing-User workspace without adapting the output path each time:
Workspace for marketing-User:
<< z:/PDFs/ >>
Target for example:
<< z:/PDFs/project_1/part_a/xyz.pdf >>
Can you help me to create the correct settings?
Thank you!! 🙂
pendean
Community Legend
Community Legend
OPTIONS command, Plot/Publish Tab, lower left corner has an Automatic Publish Settings button, all you can do is listed there with this built-in feature.
If you need to do way more than that, or need way more options/flexibility, you will need to customize with LISP and other commands instead. Ask in more detail at the customization forums here (LISP is a good place to start if you are not familiar with the other coding languages) https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
