Attribute text to be adjustable and repositionable
Often my blocks are rotated however the final text needs to remain at 0 and moved to better fit into crowded areas.  Please advise.
-M
You can grip-move the attribute as needed.
Use the command line version of -ATTEDIT
Command: -ATTEDIT
Edit attributes one at a time? [Yes/No] <Y>:
Enter block name specification <*>:
Enter attribute tag specification <*>:
Enter attribute value specification <*>:
Select Attributes:
1 found
Select Attributes:
1 attributes selected.
Enter an option [Value/Position/Height/Angle/Style/Layer/Color/Next] <N>: a
Specify new rotation angle <30.000000>: 0
Thank you.  Yes, that works individually, and might be the solution.  Is there a way to make all of the attributes for an individual block rotate as a group and move as a group?  I didn't see the individual attributes available for grip positioning edit though.
-M
When you select a block a grip should appear at the insertion point of the attribute.
Check in the lisp forum (or theSwamp.org) for a way to globally alter the attribute rotation.
or
Make the block a dynamic block forcing attributes horizontal
