Attribute text not display
Hello everyone.
I have a problem with attribute block.
As you see in the image which attacked, the number 2 is avaiable block, the number 1 is added later.
I also attack file .dwg
How can I solve this problem?
imadHabash
Hi and Welcome to AutoDesk Forum,
>> the number 2 is avaiable block <<
this is NOT the original block , FIELD text has been added later to the block attribute. symbol (#) is appeared because the object referenced  by the field is not valid.so this issue will not solved till you find the reference with your text field.and this is why in your image the block number 1 is fine because there is no text field added. see attached image
Imad Habash
john.vellek
HI @Anonymous,
When you see the #### in your block it means that the property or entity that the field was originally linked to is no longer present or available.  To correct this, you can edit the field and point it to a different property or entity.
It appears in your sample that perhaps an Xref was once attached that these labels referenced. If so, try reattaching it to see if this remedies the problem.
John Vellek
After altering a block attribute always ATTSYNC the block to rebuild the new definition.
