AUTOCAD 2010 FATAL ERROR e0434f4dh Exception at 7575812fh
Hello
I have received the below fatal error, frequently while using AUTOCAD 2010. Kindly anyone guide to sort out this error.
imadHabash
HI and Welcome to AutoDesk Forum,
I think that it's Microsoft .NET Framework issue.for that i suggest to follow this AKN link and start to solve your issue hopefully.
Good Luck..
Imad Habash
There are several ways to address the problem:
Solution 1:
1.Uninstall .NET  and reinstall the .NET  Framework
2.Uninstall and reinstall Visual C++ .
3.Clear the digital signature icons(Run->acsignopt(enter))
4.Update latest service pack and hotfix.
Solution 2:
1.Open AutoCAD 201X,From the command prompt type: RECOVER(choose the corrupted drawing)
2.From the command prompt type: -PURGE (then select "R" for Reggapps, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
3.From the command prompt type: -PURGE (then select "A" for All, then hit [ENTER], then select "N" for no on running through each individual instance then again [ENTER])
4.From the command prompt type: AUDIT (then select "Y" for Yes, then hit
[ENTER])
5.From the command prompt type: OVERKILL (then select whole drawing, then[ENTER].
6.Save the file in the AutoCAD Format.
jagan vijayakumar
john.vellek
Hi @Anonymous,
Can you tell me what operating system you are using? AutoCAD 2010 is a fairly old version and i wonder if you are using it on a system that is not for which it was designed.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
