Attribute Layer Not Changing
d_salesU937X
d_salesU937X
Hi all,
I have a text attribute within block. It currently says its on layer 0 but disappears when I turn off a different layer. And I need to move the layer to another layer called "plotnos" I have tried editing it on the block layer & the attribute editor but for some reason it won't move.
Please can you suggest what may be wrong?
Many thanks
cadffm
>>" It currently says its on layer 0 but disappears when I turn off a different layer."
You should learn more about Layer0 and in combination with properties value BYBLOCK & BYLAYER!
>" I have tried editing it on the block layer & the attribute editor but for some reason it won't move."
You edited an AttributDEFINITION, not an Attribut.
Attributes a attached to a Blockreference, based on an Attributdefinition of the block at the time of creation, after this - there is no link between.
There is a command whatz can update ALL Attributproperties (except the the text content)
Command: ATTSYNC [F1]
Read this and other threads, blogs and more about block blockdefinition blockreference attribut attributdefinition anbd their properties.
https://forums.autodesk.com/t5/autocad-forum/why-is-it-necessary-to-run-the-attsync-command/td-p/111...
https://forums.autodesk.com/t5/autocad-forum/one-attributed-block-with-different-attribute-names/td-...
Sebastian
paullimapa
Could you share a sample dwg with this block and attribute that’s not showing up on the correct layer?
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@d_salesU937X wrote:
 ...It currently says its on layer 0 but disappears when I turn off a different layer.
Most likely you forgot to drill down further inside the block first, and compare that to the block's LAYER placement. Use a tool like REFEDIT and BEDIT.
