Attribute Field Position w/ different conversion factor
eugenio_fU5HMF
Message 1 of 8
eugenio_fU5HMF
Morning Folks,
I'm trying to add the Y position of the block using the field "position" but my problem is that my sheet is set to millimeters but I need to show this position in meters (the value must be divided by 1000).
At the "additional format" table seems there is the conversion factor but it is not editable.
Any idea?
Replies (7)
Message 2 of 8
paullimapa
1 / 1000 = 0.001
Paul Li
IT Specialist
@The Office
Message 3 of 8
Kent1Cooper
@paullimapa wrote:
1 / 1000 = 0.001
All well and good, but if it won't allow you to put that into the conversion factor slot....  [I don't have any suggestions, but I don't deal with Fields very much.]
Kent Cooper, AIA
Message 4 of 8
paullimapa
You are correct I missed that.
@eugenio_fU5HMF Then I would use Formula and that allows you to enter a Conversion Factor like this:
Right mouse click in the Formula window and on the cursor menu select Insert Field
Then select BlockPlaceholder & Position, change Decimal to like 3 places and click OK
Now back in the original Field window under Formula select Evaluate button
Now you'll see the Additional Format button appear to select and the Conversion factor is now available:
Paul Li
IT Specialist
@The Office
Message 5 of 8
eugenio_fU5HMF
Thanks for your help.
Is there a way also to show the sign "+" or "-" depending if positive or negative?
Message 6 of 8
paullimapa
Mine automatically shows "-" when the y value is negative.
But AutoCAD does not show a "+" in front of positive numbers.
Are you not seeing a "-" symbol when the y value is below zero?
Paul Li
IT Specialist
@The Office
Message 7 of 8
eugenio_fU5HMF
Yes the "-" appears.
Ok I used for "+" the prefix value. I will never use the "-"
Message 8 of 8
paullimapa
Glad that works for you…cheers!!!
Paul Li
IT Specialist
@The Office
