Attribute Definition will not display
Ed__Jobe
Mentor Mentor
Message 1 of 11
Ed__Jobe
On one pc with acade, attribute definitions will not display. If I use QSELECT, only the insertion points will highlight as shown below. On another pc with just acad, the attdef's display. I can't figure out what setting is different. All my searches haven't turned up any info. Any ideas?
Ed
How to post your code.
Replies (10)
Message 2 of 11
cadffm
1. You talking about attributes or attributdefinitions?
2. Tested with the same file, yes?
Sebastian
Message 3 of 11
Ed__Jobe
1. Yes, ATTDEF's. The references display when filled. The only var I could find for att dislplay is ATTDISP but that only condtrols att reference display.
2. Yes, same file acade 2023 vs acad 2023.
Ed
Message 4 of 11
cadffm
All I know would be the same for both versions (all settings I think about are saved inside the file - so they can not be the issue)
- Layer
- Annotation scale (if they set as annotation)
- Hide Attributes (features of ACADE)
all saved inside the file 😞
Is it the same for NEW attdefs in this file=
Is it the same in another (new) file with new attdefs?
I will spend some minutes more on google for you.
Sebastian
Message 5 of 11
cadffm
No  luck, sorry.
Sebastian
Message 6 of 11
WeTanks
Is it the same for the newly added ones?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 7 of 11
Ed__Jobe
Yes, in any dwg. It has to be an app sysvar, not a dwg sysvar. I used SYSVDLG to save the settings from both apps and compared them using diffchecker. I can't find any settings that were different from each other which would control it. What ever it is, it seems to be undocumented.
Ed
Message 8 of 11
cadffm
SYSVDLG (from Expresstools) is for plain AutoCAD(a static list of sysvars), so it will only show AutoCAD settings, but issue it not related to an AutoCAD-setting.
Is it a usual font like Arial or TXT?
Attdef tag and default value without special characters?
If you know how to, did you tried a reset for Electrical?
What is are your productversions (screenshot ABOUT dialog, so we can test it with the same on our side)
Sebastian
Message 9 of 11
Ed__Jobe
Is it a usual font like Arial or TXT? Just simplex.shx
If you know how to, did you tried a reset for Electrical? Haven't tried it yet.
Using acade 2023.1.2
Just tried it with a new install of plain acad on the same pc. It can't view attdef's either. But my home laptop can. So it's something with this pc. I also tried turning of hardware acceleration, but it didn't help.
Ed
Message 10 of 11
Ed__Jobe
I found the problem. It was a 3rd party plugin (I'd rather not say which one. 😃)
Ed
Message 11 of 11
cadffm
Sebastian
