ATTOUT: Front slash (/) converted into a date format after extraction
sharpl
sharpl
Anyone knows how to prevent Excel converting "front slash" into a date format? I need it in a text format, no changes.
cadffm
two answers
1. It's on you
    How do you accee the data in Excel, by OPEN command?
    Run open, select the txt file, in Text Import Assistent, page 3of3
    select the column, change formatting to Text
2. Or , change the value befor import
    open yout txt file in Editor, search&replace / to '/
May I ask for a sample value? Because I can't reproduce it with a front slash.
Sample value "/nnn" - which one?
Crosspost https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lt-attout-gt-text-format-extracted-a...
Sebastian
sharpl
yes, i had to select a specific column, that was the key!
