pdf files look good. but when attaching to CAD, pieces of texts and drawings are missing. how do i fix.
welcome @forums.autodesk.com!
Can you upload the PDF so we can look into it?
Did you zoom close enough to see if details then appear (it's part of a perfomance issue to only display what is close enough to see it)
You might also try to open the PDF in Adobe Reader and print it again to a PDF using a 3rd party PDF-printer like PDF-Creator ... and then use this new PDF to attach it to your drawing.
Good luck, - alfred -
Aloha, please see the attachment.
I can reproduce with your PDF that some lines are missing when I use PDFATTACH with AutoCAD 2012, but it works well with AutoCAD 2017.
I have not found any way around it (but had only time for a few trials).
Have you tried to use a third party PDF-Printer to create a temporary PDF?
- alfred -
