Arcs not scaling correctly when exporting to PDF.
Message 1 of 11
Hi all,
I am a relative novice to AutoCAD. I have created a drawing that I am attempting to print to PDF. When I view the drawing in the layout page all is as it should be however when I print to PDF all arcs in the drawing seem to be offset and don't join as they should. The issue seems to be effected by the scale I choose to print the PDF ie. the larger the scale, the closer the arcs get to their original position. Does anyone know how I can fix this so as the PDF matches the image I see on the layout?
I have attached screenshots showing how the drawing appears in the model space and how it appears when printed to PDF.
Thank you in advance!Screen Shot 2016-12-14 at 13.56.33.pngScreen Shot 2016-12-14 at 13.59.02.png
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Post your source DWG file and the PDF file you created please.
Message 3 of 11
Thank you for responding so promptly.
Hopefully you will find attached relevant the .dwg and the .pdf files.
Message 4 of 11
Patchy
Plotted fine with DWG to PDF
Message 5 of 11
Amazing! Thank you so much for your help.
Okay... please humour my naivety. Can I ask what steps you took to generate that pdf? I have been trying all sort to no avail. Clearly there has been a simple solution that I have missed.
Message 6 of 11
Patchy
I can't explain why it did this:
the actual pdf is right but the preview when print is messed up.
Message 7 of 11
I am using AutoCAD 2015 on mac. The screenshot below shows the limit options I have available when trying to plot the drawing. There are no plotters to select in the drop down menu and as such I have been using the 'print to pdf' function through Adobe Acrobat. Have you any idea why I am not able to see the same plotting options that are shown in your screenshot?
Message 8 of 11
Patchy
Message 9 of 11
There is no Plot Setup menu on mac that I can find...
The process described on the link you kindly provided is the process I have been using before I created this post and is how I was taught to use AutoCAD. It was by following this process that I created the original PDF that I attached to the thread and contains the aforementioned plotting errors.
Message 10 of 11
Patchy
You could ask the folks at Mac forum for help with pdf.
https://forums.autodesk.com/t5/autocad-for-mac-forum/bd-p/520
Message 11 of 11
I'll give that a go. Thank you for all your advice. It is much appreciated 🙂
