Architectural ticks not in solid appearance
madeline.ottoman
madeline.ottoman
Hello everyone, i need help. I have problem in my architectural ticks in autocad 2020. The architectural ticks is not like a solid filled rectangular that shown at the dimension pre-settings. It just appeared like rectangular lines. Is there a way to fix this issues or something that i can set in the settings? I have found out about the shortcut key such as fillmode and stuff on the forum before ( i believe the article forum posted in 2007 ), with the same issues as me. I have tried the shortcut, however it does not work at all and nothing happened.
Note : Attachment 1 : Architectural ticks with rectangle lines (not solid)
Attachment 2 : Architectural ticks with solid rectangular in pre-settings
I set the architectural ticks in larger size to ensure that people can see the differences.
Patchy
the shortcut key such as fillmode and stuff ?
Where is this shortcut key you're referring to?
Try FILLMODE use 1
madeline.ottoman
Hello @Patchy ,
For the fillmode command, i just wondering when i am going to type the command? Is it like this steps?
1. type fillmode command and type 1
2. Put in dimension in certain area
Or it is something else?
Thank you for helping me in this problem.
With regards,
Madeline
madeline.ottoman
I have tried the fillmode command with the steps that i used on the reply post before, however nothing happened. Not sure if i had done it right
Patchy
Fillmode will not fill if the UCS is not PLAN.
Check to see if your dimensions are on PLAN view.
pendean
Community Legend
Community Legend
Show us, share a portion of your DWG file with the problem in it.
nrz13
You need to be in a 2D view for the ticks to be filled:
Enter "-VIEW" at the command line, then select "O" (orthographic), then "T" (top).
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
