AutoCAD Forum
Arc text not plotting correctly from sheetset
5 REPLIES 5
jamie_phillips
690 Views, 5 Replies
We have some arc text within our drawing sheets and since we've upgraded to 2023 every time I publish a drawing from the sheetset, the arc text is not displaying (it displays some random letters - AcDbArcALIgnedText (ATEXT). If I publish directly from within the drawing it's fine, so I'm assuming it's an issue with the sheetset?
5 REPLIES 5
JTBWorld
in reply to: jamie_phillips
Try again after disabling background publishing.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
jamie_phillips
in reply to: JTBWorld
Thanks Jimmy. That works, however, when I have 200 drgs to publish it would be ideal to have them publishing in the background. Any idea how to fix this? Thanks.
JTBWorld
Contact Autodesk with your wish. Contact Us | Inquiries And Feedback | Autodesk
Jimmy Bergmark
rkmcswain
You do not need background publishing, this is only one bad thing associated with it.
Open AutoCAD, turn OFF background publishing, start your publish job.
Open a second session of AutoCAD and work away. Your publish job above will also finish a lot faster this way.
R.K. McSwain     | CADpanacea | on twitter
tomasYDDJC
Bringing this thread back to life. We have to desks in our office with this issue, but the rest batchplot perfectly fine with no issues, all on 2023 AutoCAD. I noted the work around above, but this is tedious. Additionally there's the explode arch text work around. Has anyone found a solution?
AutoCAD
After batchplot.
Technology Administrators
