APPLOAD Command
APPLOAD Command
Message 1 of 8
APPLOAD Command
Hello
Previous to AutoCAD 2015, it used to be that when you used the appload command and browsed to a folder and then loaded a lisp command that from that folder from that point on whenever you typed appload it would start off in that same folder. It no longer does that. How do I set it to start up in a specific folder.
John
Replies (7)
Message 2 of 8
wispoxy
Command CUI or...
Message 3 of 8
As WISP stated, its best to load any custom LSP applications via the CUI manager.
Message 4 of 8
pendean
Community Legend
Community Legend
is this a REMEMBERFOLDERS variable setting perhaps?
Message 5 of 8
3wood
My APPLOAD in AutoCAD 2015 works well as previous versions.
Message 6 of 8
GilesPhillips
My 2015 version remembers the file location between session without any issue.
Perhaps if Autocad has crashed or something it forgets to 'remember' the file paths - is everyhting else working okay?
ACad, MEP, Revit, 3DS Max
Message 7 of 8
wispoxy
Unless Windows OS is set to restore default settings.
Message 8 of 8
pendean
Community Legend
Community Legend
I don't use APPLOAD to remember full time LISPs and add-ons I need all the time: only temp items. If it's broke in 2016 from 2015, there are so many ways around it while you all report the break to Autodesk and wait for a hotfix.
There are more established methods that have always worked and still work (acaddoc.lsp placement would be a good start, then the CUI method noted above etc).
