Repeat External Command
I CAN'T FIX COMMAND FILEDIA, IT'S ALLWAYS IN <0> AND I HAVE TO CHANGE TO <1> EVERY DAY 10 OR 20 TIMES. IS IT A WAY TO LEAVE THIS IN <1> LIKE NORMAL? THANKS A LOT
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
First guess is you have a tool, an application or a script running which turns FILEDIA off, but then not back to ON.
SystemVariables not restored to the original value happens also sometimes if you start LISP-tools (e.g. like MVSETUP sometimes PICKFIRST will be set to 0 and not back to it's previous value) and you interrupt the execution with <ESC> instead of going through the command until completed normally.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
h_s_walker
Welcome to the Forums
Sounds like you have a corrupted registry setting
This is where you need to look in the registry. Obviously the red text will be different for you
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD LT\R17\ACADLT-A001:409\FixedProfile\General Configuration
There should be a DWORD value there called FileDialog. It needs to be set to 1
Howard Walker
Left Handed and Proud
Do you have any customization for AutoCAD?  Apply the below to the end of your startup LSP routine.
(setvar "filedia" 1)
pendean
Community Legend
Community Legend
If the registry edit tip above did not work, and you are running a current version of AutoCAD, turn on SYSMON (set it to 2) and AutoCAD will notify you immediately after it is changed then you can figure out what tool/function turned it off for you.
