Hi all,
I am currently using Apparent Intersection to snap between a reference line and an xRef.
The issue is that at some unknown point, I cease being able to snap to many of these intersections. The first time it occurred was after I updated the said xRef. The second time was after I rotated it. Other Snaps continue to function. Apparent Intersection continues to function between lines drawn in the file.
I have tried the following to no success:
My current fix is to remove the xRef completely then reinsert it with any associated transformations and clips...
Ling.
Win10 | ACAD2010
Hi all,
Ling.
Win10 | ACAD2010
>> Win10 | ACAD2010
Just to Remind ... since your AutoCAD 2010 working under Windows 10 , then you have to know that AutoCAD 2010 is NOT supported on Windows 10.i'm afraid that you have to start from this point to solve your issue and maybe others that may expected appear in the near future .
Imad Habash
>> Win10 | ACAD2010
Imad Habash
Indeed it could be due to not actually being supported, but it is the first time anything has not worked properly in 3 years, so I figured I may as well throw it out here in case that is not the cause.
Update: rotated the xRef again and it still works.
would you check if you have any Z values for your CAD elements ?
Imad Habash
Imad Habash
They do have z values, hence why I am using "Apparent Intersection".
would you try to change your OSOPTIONS system variable , and see if any changes ? >> Click <<
Imad Habash
Imad Habash
No change with the various osoptions...
A computer with a current ACAD was free today, so I tested the file on there and could not replicate the issue, so it is most likely an ACAD2010 / Win10 conflict which has gone unnoticed by us till now...
Ling.
Ling.
