AutoCAD Forum
Apeture won't change
2 REPLIES 2
535 Views, 2 Replies
And before you ask, yes I mean aperture and not pickbox.
I am trying to reduce the sensitivity of osnaps by changing the aperture. However, no matter how big or small I make the setting, my snaps are still way too sensitive. I can move my crosshairs across a whole line that's 48 inches long and I can only snap to an endpoint or midpoint (I want to just snap somewhere along the line). I have tuned on the option that shows the aperture, and it's definitely changing astetically, however the behavior of osnaps have not changed
2 REPLIES 2
jggerth
jggerth
From that description, the only active OSNAPS are ENDPoint and MIDPoint.  If you want to be able to snaop anywhere on the line, use the NEArest osnap.
in reply to: jggerth
Thanks!
I had a lot of snaps on, but not that one...
Thanks!
AutoCAD Inside the Factory
