AutoCAD Forum
Any website for macros in use ?
7 REPLIES 7
Message 1 of 8
makdezines
897 Views, 7 Replies
makdezines
Dear All,
Any website for MAcros to automate repeated task....
Dear All,
7 REPLIES 7
Message 2 of 8
Valentin-WSP
in reply to: makdezines
Valentin-WSP
Hello makdezines,
Here are two suggestions:
Apart from this site, the Visual LISP, AutoLISP and General Customization Forum could also be a good resource.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Hello makdezines,
Emilio Valentin
Message 3 of 8
ВeekeeCZ
ВeekeeCZ
It depends whether you are looking for sources to learn from, or just to get some solutions already written.
If the first one, then the best starting point for a LISP is probably THIS  site with many additional links there.
Also, HELP is an indispensable guide.
Message 4 of 8
makdezines
makdezines
Thanks for reply..
Am looking for these kind of codes can be be perform repetitive daily CAD tasks..
Please suggest any web sites where i i can find macro codes
Thanks for reply..
Message 5 of 8
ВeekeeCZ
ВeekeeCZ
HERE  in help are some examples of menu macro usage.
Google found me THIS site which looks like it should be a good start for you.
Message 6 of 8
Valentin-WSP
Valentin-WSP
Hello makdezines,
Consider reviewing the following PDF:
Emilio Valentin
Hello makdezines,
Emilio Valentin
Message 7 of 8
andrew.herrick
andrew.herrick
I think "Multiple" might be the command you need in autocad. - Repeats Command.
Message 8 of 8
TomBeauford
TomBeauford
About Special Control Characters in Command Macros
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-DDDB6E26-75E1-4643-8C6A-BEAEBA83A424&p=ACDLT&...
Repeats a command until another command is started or the current command is ended.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
2023
AutoCAD Inside the Factory
