AutoCAD Forum
Any website for macros in use ?
7 REPLIES 7
Message 1 of 8
makdezines
819 Views, 7 Replies
Dear All,
Any website for MAcros to automate repeated task....
7 REPLIES 7
Message 2 of 8
Valentin-WSP
in reply to: makdezines
Hello makdezines,
Here are two suggestions:
Apart from this site, the Visual LISP, AutoLISP and General Customization Forum could also be a good resource.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 3 of 8
ВeekeeCZ
It depends whether you are looking for sources to learn from, or just to get some solutions already written.
If the first one, then the best starting point for a LISP is probably THIS  site with many additional links there.
Also, HELP is an indispensable guide.
Message 4 of 8
makdezines
Thanks for reply..
Am looking for these kind of codes can be be perform repetitive daily CAD tasks..
Please suggest any web sites where i i can find macro codes
Message 5 of 8
ВeekeeCZ
HERE  in help are some examples of menu macro usage.
Google found me THIS site which looks like it should be a good start for you.
Message 6 of 8
Valentin-WSP
Hello makdezines,
Consider reviewing the following PDF:
Emilio Valentin
Message 7 of 8
andrew.herrick
I think "Multiple" might be the command you need in autocad. - Repeats Command.
Message 8 of 8
TomBeauford
About Special Control Characters in Command Macros
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-DDDB6E26-75E1-4643-8C6A-BEAEBA83A424&p=ACDLT&...
Repeats a command until another command is started or the current command is ended.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Forma Design Contest
