Annotative text height missing from dropdown list in Quick Select tool
caddude
caddude
Hello all,
I wanted to find some text that may be a different height in a drawing and was using the quick select tool to try and locate that text.  I set my object type to text and when I look through my properties list, height is missing.  If I use non-annotative text, the height property is there.  Is there any idea why it's missing for annotative text?QUICK SELECT MISSING ANNO TEXT HEIGHT.png
imadHabash
i suggest to change the Annotative scale from below status bar to the scale that you want to find .  and regarding your list the ... it's normal to not find text height option because you're treat with Annotative text object .
Imad Habash
pendean
Community Legend
Community Legend
That's not an ability found in QSELECT yet.
caddude
@pendean Thank you for letting me know.  Hopefully that will be added soon.
pendean
Community Legend
Community Legend
caddude
Just sent it in.  Hopefully that gets added in the next release.
Thank you for your help!
InfraSolutions_Colin
If I could add to this solution. The QSELECT tool cannot use Text Height as a search criteria if the majority of the text is Annotative.
If most of the text is not annotative, you will be able to search based on height in QSELECT.
(I have tested this in AutoCAD 2021)
