PDF File doesn't scale properly when exporting
kali.mailhot
Message 1 of 9
kali.mailhot
When I print to my plotter from autocad it prints perfectly, however when I have to export it to PDF the PDF adds extra space. Usually on one side there is a large blank space which doesn't allow the file to scale properly. Any suggestions would be greatly appreciated.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
PDF files have larger margin requirements than most physical plotters and printers: is that what you see?
Or are you just not printing the PDF file to your plotter to scale due to a missed setting in the PDF viewer's print pop-up?
Explain please.
Message 3 of 9
imadHabash
i suggest from PLOT command >> Select DWG to PDF.pc3 printer .
Imad Habash
Message 4 of 9
kali.mailhot
I'm not printing the PDF file, I am exporting it to PDF to send to others via email but when I do export a large blank space is inserted into the side of the PDF. Much larger than a normal margin.
Message 5 of 9
kali.mailhot
I will try that thank you
Message 6 of 9
kali.mailhot
Message 7 of 9
GrantsPirate
Did you try picking Landscape instead of Portrait?
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 8 of 9
kali.mailhot
Yes I have tried that
Message 9 of 9
pendean
Community Legend
Community Legend
PLOT command gives you way more controls than the 'export' option, start there, pay attention to the WHAT TO PLOT options.
