Annotative objects appear different in 2 computers.
lsantiagoHTS8A
Message 1 of 18
lsantiagoHTS8A
Hello
Ihave a problem in my office we begin introduce annotative object (Dimensions, Multileadres ETC. ) 2 months ago but in our drawings we have a problem. The same drawing shown different annotation scale in 2 computers. Does Any know some variable command or setting?.
Replies (17)
Message 2 of 18
Alfred.NESWADBA
Can you show the difference?
My first idea for that... the annotative text uses a font that exists on one computer, but not on the other computer. And in that case a replacement font is used that might look different. Start command _STYLE and see if any of the defined text styles does not find it's font (yellow warning marker)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 18
natasha.l
Hello @lsantiagoHTS8A
Thanks for posting.
I see that you escalated this case we can further assist you with this issue. We have an article here that will guide you through what to do, you first want to determine if that font is not present on the computer as mentioned.
If the font is not present please review the options below:
1. Change the text style to a font that is available on both computers
or
2. Install the font file on the other computer
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 4 of 18
lsantiagoHTS8A
MY COMPUTER
[image: image.png]
PARTNER COMPUTER
[image: image.png]
Message 5 of 18
Alfred.NESWADBA
no screenshots arrived, please do not use email to answer when you want to attach files.
Instead use your Internet browser to go to the forum post and use the reply button, there you'll find an option to attach files.
BTW: have you verified if fonts are missing?
- alfred -
Alfred NESWADBA
Message 6 of 18
lsantiagoHTS8A
this is our computers Spec
Brand=HP  -  Processor=intel core i7 @ 360 ghz  -  Ram=32.0 GB
Program: AutoCad 2018
I change the font in the 2 Computer but the problem still the same.
Message 7 of 18
Alfred.NESWADBA
can you please ... on both workstations
  • open the dwg
  • press <F2> to get the bigger version of the command line
  • create a screenshot (so we see what happens when the file is loaded, like showing font replacements, plugins loaded, ...)
  • then start command _ABOUT
If you can upload the dwg-file it would be great to see how it looks like on our systems.
- alfred -
Alfred NESWADBA
Message 8 of 18
We are experiencing the same issue. Has anyone found a solution to this, yet ?
Message 9 of 18
vinodkl
Select the annotative object and open properties(ctrl+1) in both systems and see in the annotation scale is same. Also check if system variable "ANNOAUTOSCALE" is set to "2" in both the drawings. If not, then set it "2" and change the annotation scale to different scale and then back to the original one.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 10 of 18
The issue is, the same annotative objects look different in different computers.
I am attaching two screenshots so you can see the problem.
We run battman, and sync the block, and the block appears in correct size in one computer, but then it becomes a problem in another.
Message 11 of 18
cadffm
I am pretty sure you are NOT talking the same file! (OR not talking about full updated softwareproduct version)
Compare the same file
and show use the productversions (of both systems), Command: ABOUT
Sebastian
Message 12 of 18
natasha.l
Hello @Anonymous,
Have you applied the suggestions or alternatives?
Message 13 of 18
lsantiagoHTS8A
I uploaded the file to will be you can revised or checked the file.
I changed the variable ANNOAUTOSCALE in the two computers but the problem still happen. Also i uploaded the Autocad text window when i open the file to you can see and check.
Thank You for your help.
Message 14 of 18
It is the same file , and it is the same version !
Message 15 of 18
lsantiagoHTS8A
Is the same file.
I Uploaded the versions of Autocad software.
Message 16 of 18
Alfred.NESWADBA
your partner has not updated AutoCAD LT to 2018.1.2 ... he's just using 2018
- alfred -
Alfred NESWADBA
Message 17 of 18
lsantiagoHTS8A
Not he's just using 2018. Does he need update the software to it annotations work correct ?
Message 18 of 18
Alfred.NESWADBA
first we need to have 2 equal releases, then we see if updating the other workstation solved it.
With different software releases it does not make sense to compare differences in the results.
- alfred -
Alfred NESWADBA
