AutoCAD Forum
Annotative Block Leader
1 REPLY 1
398 Views, 1 Reply
I've created a leader with a block as the multi-leader type. The block is saved as annotative and the leader is annotative. When both are set to annotative, the block disappears. I've tried different settings for the leader scale and can't get the block to show up. Does anyone have any experience with this?
1 REPLY 1
Figured out why it disappeared. Annotative blocks can't be used for leaders. I changed the block to annotative after creating it and AutoCAD removed the block. Hope this helps anyone else with the same problem.
Forma Design Contest
