AutoCAD Forum
Angular dimension style
2 REPLIES 2
manneska1
1164 Views, 2 Replies
Hello everyone,
I've been trying to set up a new dimension style. I've worked most of it out by googling and youtubing.
However, there's one thing that I haven't been able to figure out. I've added an image to display what's wrong..
As soon as the text of the dimension is too far away from the object that I'm trying to dimension, the lines aren't 'attached' to the object anymore.
What's the fix?
Thanks in advance.
2 REPLIES 2
imadHabash
in reply to: manneska1
DIMANGULAR command will achieve what you asking for.when quadrant behavior is on, the dimension line is extended past the extension line when the dimension text is positioned outside of the angular dimension.
Command: DIMANG DIMANGULAR
Select arc, circle, line, or <specify vertex>:
Select second line:
Specify dimension arc line location or [Mtext/Text/Angle/Quadrant]: q
Specify quadrant:
Dimension text = 36
Good Luck..
Imad Habash
manneska1
in reply to: imadHabash
Thanks for the reply! That's indeed what I was looking for.
Forma Design Contest
