Angular Dim Text Fix
nfisher
nfisher
Trying to figure out if there is another option for the attached photo. It would be cool if the text could arc with the dim style, is this possible?  Is there also a way to add a text to a dim that shows up below a leader? see other attached photo.
Let me know,
Thanks!
Nate
natasha.l
Hello @nfisher
Thanks for posting to the community.
You can edit the dimension lines text by selecting it & right-clicking the grip.
You can also use ArcText command to place text along a arc using Express Tools. I am not aware of making this change to Dimension Style as this would apply to the set dimension style that is current & I don't think you'd what that in every case.
I hope this helps answer your question or gave you some helpful information you can use.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
