AutoCAD Forum
Alphanumeric grid
5 REPLIES 5
662 Views, 5 Replies
Alphanumeric grid
Hi everyone,
I would like to create an alphanumerical grid with customizable dimensions. I have included a picture of what I would like to make. I would appreciate any advice you may have on how to create something like this.grid.PNG
Thank you,
Ian
5 REPLIES 5
Patchy
in reply to: Patchy
This will be used for a photolithography mask to produce small square
patterns. There are thousands of squares for each design, and I will need a
way to not get lost while examining the squares under the microscope. I
want to space the markings every 10 squares, and maybe even delete the
squares underneath the grid markings for easier reading. Here's a picture
with the grid overlaid with the squares.
Patchy
The unit is important, do you need them in mm?
in reply to: Patchy
The unit is in centimeters.
Patchy
Seems too basic for a beginner, have you try to draw it?
The drawing is attached, modify it it to fit your need.
Forma Design Contest
