AutoCAD Forum
all toolbars missing!
10 REPLIES 10
Message 1 of 11
2049 Views, 10 Replies
All my tools bars are missing following starting up my pc this morning - it was fine when i shut down last night.  i have checked the clean screen option and that is off.  What is also strange is that my saved workspaces are not available either - its like everything has been deleted!
Hopefully someone can advise as i need to urgently get back to work
thanks
Ray
thanks
Ray
10 REPLIES 10
Message 2 of 11
imadHabash
imadHabash
it's weird to loose your workspace and toolbars !!! have you start AutoCAD from the same user name ?
try from Tools tab ( Menubar = 1 ) go to Toolbars >> AutoCAD .
Imad Habash
Imad Habash
Message 3 of 11
in reply to: imadHabash
hi there,
thanks for getting in touch
username is the same
just tried menubar 1 and it is already on this value
Any ohter ideas?
thanks
Ray
hi there,
Any ohter ideas?
thanks
Ray
Message 4 of 11
imadHabash
imadHabash
have you check Tools tab
Imad Habash
Imad Habash
Message 5 of 11
i have looked but i do not have this to select - this and all the toolbars i normally have are all missing - attached is a screen shot
Message 6 of 11
imadHabash
imadHabash
try to load acad.CUIX from menuload command >> Browse .
Imad Habash
Imad Habash
Message 7 of 11
unfortunately the cuix file is not in the list.....! screen shot 2 attached
thanks
Ray
thanks
Ray
Message 8 of 11
imadHabash
imadHabash
Ok ... close your AutoCAD and try to reset AutoCAD to default settings . >> Click <<
Imad Habash
Imad Habash
Message 9 of 11
i tried loading the acad.bak file instead and it has worked! Closed and reopened and everything has returned
thanks for you help
Ray
thanks for you help
Ray
Message 10 of 11
RobDraw
RobDraw
What are toolbars?
Rob
What are toolbars?
Rob
Message 11 of 11
joelichty
joelichty
Community Visitor
Community Visitor
This worked for me with same issue.
AutoCAD Inside the Factory
