All my tools bars are missing following starting up my pc this morning - it was fine when i shut down last night. i have checked the clean screen option and that is off. What is also strange is that my saved workspaces are not available either - its like everything has been deleted!
Hopefully someone can advise as i need to urgently get back to work
thanks
Ray
thanks
Ray
it's weird to loose your workspace and toolbars !!! have you start AutoCAD from the same user name ?
try from Tools tab ( Menubar = 1 ) go to Toolbars >> AutoCAD .
Imad Habash
Imad Habash
hi there,
thanks for getting in touch
username is the same
just tried menubar 1 and it is already on this value
Any ohter ideas?
thanks
Ray
hi there,
Any ohter ideas?
thanks
Ray
have you check Tools tab
Imad Habash
Imad Habash
i have looked but i do not have this to select - this and all the toolbars i normally have are all missing - attached is a screen shot
try to load acad.CUIX from menuload command >> Browse .
Imad Habash
Imad Habash
unfortunately the cuix file is not in the list.....! screen shot 2 attached
thanks
Ray
thanks
Ray
i tried loading the acad.bak file instead and it has worked! Closed and reopened and everything has returned
thanks for you help
Ray
thanks for you help
Ray
What are toolbars?
What are toolbars?
This worked for me with same issue.
