All horizontal line is different in colour.
as975889
as975889
Community Visitor
Community Visitor
When I draw a horizontal line in my AutoCAD 2024 it's look different then vertical lines colour of horizontal line is also blue and I am unable to change the colour of line.
X axis of UCS is aloso blue.
And crosshair horizontal line is also blue.
Kindly provide me a solution.
Valentin_CAD
@as975889 ,
Welcome to the AutoCAD forum.
Provide a visual image of the issue.
In the meantime, try to "Restore classic colors" from the Options...
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
Have you installed the 2024.1.2 Update yet? ABOUT command in your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2024.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, and start a support ticket through your subscription portal as explained here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
HTH
wispoxy
  1. Graphics Card Settings:
    • It appears that AutoCAD might be using the incorrect graphics card. To resolve this:
  2. Color Settings:
  3. Video Drivers and Hardware:
  4. Invisible Line and Cursor Display Issue:
