AutoCAD Forum
align parallel mleaders
6 REPLIES 6
jdfnnl
346 Views, 6 Replies
Is there a way to use MLEADERALIGN to align all the text vertically while also maintaining their parallel position?
6 REPLIES 6
pendean
in reply to: jdfnnl
Those mleaders' landings look like they've been manually edited/stretched, correct?
Can you manually fudge what you are looking for and post an AFTER screenshot please? Your BEFORE screenshot alone is not enough.
jdfnnl
in reply to: jdfnnl
manually accomplished:
pendean
in reply to: jdfnnl
so your priority / wish is to maintain these angles?
If yes, nothing OOTB does that: the tool prioritizes the text on the other end of the MLEADER
jdfnnl
in reply to: jdfnnl
what is OOTB?
Washingtonn
in reply to: jdfnnl
Out Of The Box - as the AutoCAD software comes from AutoDesk (in this case)
pendean
in reply to: jdfnnl
Forma Design Contest
