Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD Forum
Adding image
8 REPLIES 8
Message 1 of 9
1240 Views, 8 Replies
Adding image
Hi I have a problem with the AutoCad 2017. I need add to my project a
picture in .BMP format. The problem is that the picture backround and
foreground are replaced. When i turned on transparency then the
picture backround still have colour of layers while the picture colour
are transparent. In previous version of AutoCAD this was vice
versa. Backround of picture was transparent and picture foreground
colour was just like colour of layers. I hope that you can help me
solve this problem, otherwise i must back to previous version of
AutoCad.
8 REPLIES 8
Message 2 of 9
imadHabash
Hi and Welcome to AutoDesk Forum,
it will be more helpful if you show us an image or post the CAD file itself.
Imad Habash
Message 3 of 9
beyoungjr
Are you attaching the bmp image as a reference or as an OLE object?
If reference then the path to the picture is relevant.
Blaine Young
Senior Engineering Technician, US Army
Message 4 of 9
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 I imagine that you are trying to place a logo or such. Is it possible to share the image file and the drawing file on a post? I am happy to look at the issue for you.
John Vellek
Message 5 of 9
in reply to: imadHabash
Ok.
Screen for AutoCAD 2017, I can send after eight hours.
In 2014 version of program all is fine
Message 6 of 9
I don't have my computer with me, but i asked my girlfriend to do screen. She do not know AutoCAD that is why the image is rotated.
As I said the background image is the color of the layer. The colors in the picture are my drawings, they are not relevant.
Message 7 of 9
imadHabash
I suggest to do the follow to get what you need and as attached below image :
  • open your image from Paint tool.
  • Ctrl+A to select all then Ctrl+c to take a copy image from it while you open it from Paint.
  • keep Paint opened and go for AutoCAD.
  • type PASTESPEC command and select Image Entity (see below image).
Imad Habash
Message 8 of 9
I try this after backing to home.
Thank you for your commitment.
Message 9 of 9
It working, thank for help. Well, why the insert option don't work propely in AutoCAD 2017?
The same file .dwg looking correctly on previous program version and incorrectly on latest 2017. If only I have this bug, maybe that are bad settings?
AutoCAD Inside the Factory
