AutoCAD Forum
Adding custom lineweights
4 REPLIES 4
14578 Views, 4 Replies
hi i was wondering if anyone knows how to add extra custom line weights the standard cad will go up to 2.11mm but i want to add ones upto and above 6mm, We use standard AutoCAD2018 and C3D2018
4 REPLIES 4
dgorsman
dgorsman
You would be using polylines for those.
BrianBenton
BrianBenton
You can't "add" or "remove" lineweights. BUT...you can create and edit Plot Styles if you use an STB file to control your printing. Create a new PLOT STYLE, call it something, then click on the EDIT LINEWEIGHTS button, change an existing lineweight and use that one. Unfortunately you can't add/remove lineweights, you can only change existing lineweights. So find one you don't use and change that one. This doesn't affect the lienweights in the drawing/object/layer only in the plot style you use to control the objects.
This is a convoluted approach but it might get you what you want?
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
Brian C. Benton
in reply to: BrianBenton
this would be handy if I was using Black or the standard colours the issue is I use all the colour books
cadffm
cadffm
Use named plotstyles/stb
Sebastian
Sebastian
AutoCAD Inside the Factory
