Add-A-Plot-Style-Table-Wizard error
1wildwes
1wildwes
I have a new User with just installed C3D 2019 Win 10 getting the attached Add-A-Plot-Style-Table-Wizard error.
I've checked Option paths and all match other Users. No one else gets this error message. All the Add-A-Plot-Style-Table-Wizard shortcuts work.
RobDraw
There is a shortcut at that location that needs to be deleted.
Rob
pendean
Community Legend
Community Legend
The error message says those link files are damaged/pointing to something that is damaged or no longer in place.
Not sure "checking" is the correct solution, you will need to actually remove and replace with all new (or from someone else'c C3D 2019 setup). Give it a try.
1wildwes
These are not something we use. If I delete them would I still get an error message such as Not Found, etc?
RobDraw
Please see message #2.
Rob
1wildwes
Here is what solved the issue. Only the Solution portion applied in my case.
