i made a macro thru action recorder and when i use it, the end zips back over to where i originally made the macro. so anyway to turn this off? its not in the macro step tree so i cant delete it.
how do i stop it from going back? or do i have to redo the macro a certain way?
Solved by nicholas_friesenYGF4U. Go to Solution.
I must admit that I don't have much experience with action macros, but one way (maybe?) would be to add a View save at the beginning of the macro and then a View restore at the end.
In the Manage tab, expand the Action Recorder menu for the macro you would like to edit. Right-click the name of the macro and click on Properties. In the Properties menu, make sure both of the boxes under Restore pre-playback view are unchecked.
