I made a few simple Action Macros to automate some steps. I can’t figure out why my Action macros are not fulling loading.
I see them in my list when I have a drawing open but when I go to change the macro I want to use, my drawing seems unable to find the desired macro and runs the default listed macro instead.
I don’t see any issues with my file paths in the options. I open the folder and I see my .actm files.
The weird part is, I can override this flaw by switching workspaces.
If I switch to any workspace and then go back to mine I can get the pulldown menu to accept my choice action. But I have to do the switching between each macro I want to run.
Please let me know if you need any clarifying information.
I am aware of lisp routines and such but I have no idea how to create them so I am stuck with action macro for now.
Does anyone know or have suggestions on something that might be causing this problem for the action macros?
Solved by hillary.wilmerPE3E5. Go to Solution.
I spent all morning making my first screencast for this question. and I'm a bit pissed at myself for not getting it to post properly with my question. I can find the screencast and I seem to be going through the motions to post it but nothing is happening.
thank you for your patients as I figure this out. I think I got it but it wasn't using the process that appear below this window. cause right below where I type this now there is a place to insert 'My Screencast' and I find it on the pulldown menu and hit insert but that seems not to be how to upload the file. functions seems as janky as the action macros...
I haven't been able to find any useful information for WSSETTINGS. I keep messing with the dialog box settings to see if something changes but I can't see any results if this setting is what affects my problem. So as of now, I don't have a solution. This problem is still valid and some other suggestions would be appreciated. I don't know if I'm one click away from a solution or if I'm going down the wrong path.
this is the only post on knowledge.autodesk.com I could find about WSSETTINGS.
The WSSAVE command was not enough to fix the error. It had to have been some sort of linking issue with the changes I made to my CUI in my workspace. No matter what I did before I re-did my workspace and custom tab the WSSAVE command did not save the changes to the workspace. I ended up starting over and completely recreating the workspace and custom tab. my action macros are now working.
