Accidentally applied a anchor or a constraint to my drawing ....
jim3thornton
Message 1 of 10
jim3thornton
Recently I have found that lines drawn are anchoring them selves to other lines ...
I don't know if I have inadvertently initiated a  command but I notice that when a line has been drawn ... I will hover the cross hairs over the line and see that small symbol appears like a backwards "Z"...
In some circumstances I have tried to move an object and other line work follows with the move ...
Any comments would be helpful ... thank you
Replies (9)
Message 2 of 10
john.vellek
Hi @jim3thornton,
Can you share a screen capture? If you have applied a constraint, you can use the DELCONSTRAINT command to get rid of it.
John Vellek
Message 3 of 10
jim3thornton
One problem is I'm working on Autocad Architecture today .... so I don't know if that makes the solution any different ...
The cross hairs disappear when I try to screen capture ...
Message 4 of 10
john.vellek
Hi @jim3thornton,
Are you using the Windows snipping tool for the capture?
John Vellek
Message 5 of 10
jim3thornton
I was on a surface yesterday ... I was able to print screen today to provide the attached pdf...
what is interesting is i worked on two files yesterday and both files exhibited the same setting ...
where as today ... the first file i had not sign of the problem ... but the second file still has the condition ....
see the attached pdf for the symbol next to the crosshairs
Message 6 of 10
john.vellek
Hi @jim3thornton,
Can you share the file that still shows the problem? If it needs to be private, you can email to me at [email protected]. Please include a link to this thread in your email.
John Vellek
Message 7 of 10
john.vellek
Hi @jim3thornton,
Thanks for sending me the drawing.  That symbol appears to be an Auto Constrain indication.
John Vellek
Message 8 of 10
jim3thornton
i have sent you the email
Message 9 of 10
jim3thornton
then I may have accidentally turn it it on ...
then have would i disable it?
Message 10 of 10
john.vellek
Hi @jim3thornton
You can certainly use DELCONSTRAINT to remove this.
John Vellek
