Accidental Move with Click and Drag
ryan_anderson
Message 1 of 13
ryan_anderson
Every so often, I unintentionally move objects by panning or selecting on things while working. Is there a setting to turn off "click-drag-move?"...sorry for the lack of better words.
Thank you,
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
@ryan_anderson wrote:
....Is there a setting to turn off "click-drag-move?"....
Not to be confused with the system variable with the same name...
Message 3 of 13
ryan_anderson
I think this is what Im after?....Im confused
Message 4 of 13
pendean
Community Legend
Community Legend
Yes. Only thing holding you back now is just trying it.
Message 5 of 13
ryan_anderson
Gotter dialed in sir.
Thanks for being a huge help over the years, patrolling these forums!
Much appreciated!
Message 6 of 13
pendean
Community Legend
Community Legend
Thank you for the compliment, an you are most welcome.
Message 7 of 13
ryan_anderson
So the issue is when I left click and highlight a block or object, then accidentally left click the same object and drag the mouse, the highlighted block/object will move. It is always unintentional.
What is strange is that the move does not show up in the command line?
I appreciate you bearing with me as I try to explain this.
Message 8 of 13
cadffm
there are two function and the left one is the standard windows feature drag&drop.
You will find more about by searching for "DROPGEOM"
Also a code to supress this feature only (not the whole windows standards).
But I prefer: Train to use the mouse more accurate.
Sebastian
Message 9 of 13
ryan_anderson
"Train to use the mouse more accurate" LMFAO
Message 10 of 13
pendean
Community Legend
Community Legend
DROPGEOM is an interesting ability if you want to explore it
https://www.cadforum.cz/en/qaID.asp?tip=3939
Message 11 of 13
pendean
Community Legend
Community Legend
...when I left click and highlight a block or object, then accidentally left click the same object and drag the mouse, the highlighted block/object will move...
Beware of the "slow" right-click action: your 3rd party mouse driver might let you fix the issue by changing the timing for a long click (called something like minimum hold time or something like that).
Message 12 of 13
Alexander.SanchezVBJ2Z
I loathe the click + drag option. I often work in a remote citrix environment, and so with that little lag my session often interprets my selections as click drag. I have wished for many years for a variable to be introduced to disable this functionality.
Hilarious enough I see below the comment section "Drag and drop here or browse files to attach". Almost as if it is mocking me hahaha.
Message 13 of 13
zhuluyao2011
Alias has the same problem and I have not found a solution to it yet.
