AutoCAD Forum
A Tracing program for lazer cutting.
2 REPLIES 2
297 Views, 2 Replies
Hi, I am new to Autocad and i hope you can help me with some advice.
I am wanting to lazer cut an image of a horse on mild steel using a DXF File. I know i can attach the image onto Autocad and manually trace using Spline and Polyline etc.
Does anyone know of a program or a process that i could use to trace the attached image for me rather than me spending lots of time manually tracing?
Any info is much appreciated,
John H,
2 REPLIES 2
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 There are bunches of apps both online and stand-alone that can "vectorize" a raster image. Some work better than others.  Can you share a sample image on a post so I can see what you are starting with?  In the mean time, you might check out Inkscape (freeware) and look at the process to find and save paths (outlines).
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Forma Design Contest
AutoCAD Beta
