Hello, I'm a student who just started autoCad few weeks ago. Currently, I'm facing issue with my drawing. The layout doesn't appear completely, what i've drew is appeared half only. Please guide and help me and much appreciate it.
Thank you
hello, first of all those objects that are missing could be layers are freeze of defpoints change to another layer? second go to options and untick your hardware acceleration. thanks
Are all the objects that don't show up on the viewport either text, dimension or leader objects?
If so, are they annotative text/dimensions/leaders? Is the annotative scale of the objects different to the annotative scale of the viewport?
if you don't know how to check, here's how...
Open the properties pallette while you have one of them selected (type PROPERTIES), there should be an entry 'Annotative' yes/no
If they are annotative, check what annotative scale is assigned to them.
Then, in paper space, select your viewport and look at its properties:
If the annotative scale of the viewport is different to the objects then they may not display.
Three solutions:
1. Make sure the scales are the same
2. Don't use annotative dims/text (just control the sizes/scales in model space)
2. Set your ANNOALLVISIBLE to 1 rather than 0.
All good suggestions so far, but if you post the dwg instead of just images you will get a definite answer faster instead of just guesses.
Nick DiPietro
Cad Manager/Monkey
