a small doubt regarding renaming a block using block editor
KOTARAMMOHANR
KOTARAMMOHANR
i want to rename a block using block editor .   i am saving the block with another name in block editor then after i had closed block editor . but in current insert block gallery with old name one block showing and with new name same block showing what i have to do
AVCPlugins
Why not use the _Rename command? Or there are handy plugins: A>V>C> Properties palette  and AVC AsmNew command
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
KOTARAMMOHANR
why blockeditor showing such problem i cant unerstand
cadffm
There is no problem, it is just how it works and you expects different.
You can not change the name inside bedit.
"Save as" Option is for create a new block!
Useful for block creation for blocks with similar shape or settings.
If you like to rename a block, use RENAME as mentioned above.
Sebastian
