Publish window: allow to insert path
iCs-tna
iCs-tna
Dear Autocad users,
what is bothering since years by using the publish mode: when you choose the path, you need to click to the folder where you want to publish it. You can not insert a path in line. Usally I have the folder I'm working on open and it would be way easier just to copy/paste the publish path. As I usual I'm using a work-around (Autodesk favourite way to work): I create a shortcut on the desktop and I use the shortcut to get fast to the desired path.
If you could add the line, where you can copy paste paths it would make things 10x easier!
I added some screenshots how it looks like, and how it should look like
cadffm
Welcome to AUTOCAD board,
where you talk to other users (only).
Civil3D Idea board is over here: https://forums.autodesk.com/t5/civil-3d/ct-p/4003
Sebastian
iCs-tna
Publish is always the same in all Autocad versions. C3D, Architecture...
cadffm
Feel free to post your idea to all idea boards,
but you can't find a "AutoCAD idea"
that's why i posted the link to C3D idea.
(perhaps you didn't understood: You  are in a user forum, not at Autodesk company support office)
Sebastian
pendean
Community Legend
Community Legend
"Autodesk" is a company: not a workflow or a software.
AND... We are all end users just like you in here.
Autodesk looks for software product feedback over here only, start there now, don't wait https://www.autodesk.com/company/contact-us/product-feedback
