Hi!
I get a file, it only shows a certain list of Plot Style (PS).
I tried several options to fix it:
Import plot styles from other
PU,Audit.
add Support path: Plot style table.
but they are all ineffective.
I don't know if there is a variable system that controls the display of PS!?
Attached file is blank file from it
Thanks for any help.
Solved by paullimapa. Go to Solution.
whoever provided you with this drawing will also have to provide you with the plot style table used. Or else it becomes a guessing game.
I want to apply the existing plot styles on my Pc to this drawing. But it cannot load into this drawing. That's the question I'm wondering. When I open other files. It shows my plot style again.
most likely this drawing is using stb plot styles and you want to apply ctb plot styles or vice a versa. Use Convertpstyles
glad to have helped...cheers!!!
