A Bit Fancy - Text ACCURATELY placed on a curved surface
Drewpan
Advisor Advisor
Drewpan
Hi All,
I have FINALLY finished my homework. The last Drawing was a Micrometer. Yay!
BTW this is NOT my homework. It is something I can see I might need to know how to
do in the future that I want to learn.
Ok, so I can hand it in and I will pass but I wanted to get a bit fancy and work out
how to put the graduated scale on the Sleeve and the Spindle. I can think of a few
ways I might be able to do it but can't actually get it to work. What I want is this:
There is a simple Linear Scale on the Sleeve which would involve a combination of Text
and 2D lines. I can draw it in 2D but how do I project this onto a Curved surface?
Next there is the Graduations on the Spindle. This is also a series of graduations and
text, but this has to be accurately spaced around basically a donut wedge. My
thoughts were that the graduations can be accurately placed with the Polar Array
but how do I do this, and how do I get the text in the right place without painfully
typing it in manually?
Your advice would be much appreciated.
Cheers
Drewpan
vinodkl
Check this: https://forums.autodesk.com/t5/autocad-forum/wrapping-text-to-fit-a-curved-surface-in-autocad/td-p/7...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
j.palmeL29YX
Before I explain a possible way - is this (see attachments) what you want to achive?
Jürgen Palme
Drewpan
Thanks for answering.
That is what I want but is actually the next step to where I want to be for this problem. I
am having issues also getting embossing and engraving to work.
What I want to do is put the linear scale on the yellow part, and an accurate circular scale
on the inclined surface between the yellow part and your number. For now I just wanted
the text and the scale but the engraved effect is ultimately what I would do.
If I was designing a Micrometer for real then this would have to be very accurate, not just
for show. The Graduations would need to be in exactly the right place and the text more or less
in the right area. What I mean by that is that the text would only need to be above the right
graduation, although say 1mm above and centred would be the desired effect.
Drewpan
