3DCONFIG Tuner Log Documentation
brian.strandberg
Advisor Advisor
brian.strandberg
If I export the Tuner Log I get a bunch of interesting fields.  Are these documented anywhere?
Certification Status 5
Hardware Feature Level 51
Software Feature Level 50
Using this command sequence:
-3DCONFIG
Tuner Log
Filename
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
chenchri
Hi Brian,
Thanks for your questions.  These are primarily for our internal debugging purposes - They help us determine the issue when you have graphics configuration problems and send this to support.   You don't need to worry about them if you are already running DirectX 12.  There's no user documentation for them.
Christopher Chen
AutoCAD Test Development
brian.strandberg
Thanks for letting me know, I appreciate the information.
I'm always looking for more information I can collect on our computers so that when they report issues to me and the IT department I can use this for debugging.
I have code that collects the Video Card and Driver Version so I can check if they are on hardware or software acceleration.
Current breakdown is:
Dx12 63%
Dx11 20%
Gdi16.hdi 17%
