AutoCAD Forum
3DClip still shows dimension texts
2 REPLIES 2
554 Views, 2 Replies
I am using a Custom UCS with a 3DClipped view to zoom in on a vertical element, directly in front of it there's second element hiding it (therefore the 3DCLIP).
The element in front also contains dimensions with their text, the dimension lines are not displayed, but the text is (backwards).
Is there a way to get rid of the text via 3DCLIP or via another method (apart from hiding it via a layer)?
Tags (3)
Labels (3)
2 REPLIES 2
dmfrazier
See if changing the HideText variable makes any difference.
in reply to: dmfrazier
Sadly no difference, variable was set to ON, I tried setting it to OFF
Forma Design Contest
