3D-Scale Problems - Cannot Select individual Axis.
matias.medves
Observer Observer
matias.medves
Observer
Observer
Hey guys, I'm working on a SIMPLE 3D project. I'm trying to scale in the Z axis a box I drew, but the scaling "GIZMO" is restrained to all three axis, I cannot select individual axis no matter what I try. I really need help guys.
Gabriel_Watson
Kent1Cooper
If you drew it using the BOX command specifically, then you can change the height in the Properties palette:
If you drew it by [for example] EXTRUDEing a rectangle Polyline or PRESSPULLing in one, then you can't do it that way, but you can grip-edit the height of it in 3D view [which you can also do with one made by BOX].
In any of those cases, the (getpropertyvalue)/(setpropertyvalue) method can be used to change it, and an AutoLisp routine could be defined that would calculate and impose a new Height value for you, based on the current value and your desired scale factor.
If you want to Scale it by a specific factor without such an AutoLisp routine, not knowing what that's going to mean in terms of a new Height value or a grip-editing distance, then define it into a Block, and change its Z scale factor.
There would be cases where only the define-as-Block approach will work, such as if it is the result of a SLICE command.
Kent Cooper, AIA
j.palmeL29YX
Depending on what you have and what you want to achieve (both we don't know) also the SOLIDEDIT... command perhaps can help you to reach your goal.
Jürgen Palme
