3d Path Array
3d Path Array
Message 1 of 8
3d Path Array
How to 3d path array an object with a specific slope. Any idea or Lisp?
Replies (7)
Message 2 of 8
imadHabash
usually i do this by draw this object at slope angle then i use 3DARRAY (Rectangular) command.
  • draw the object that you want to array.
  • make your UCSICON at the same slope level by using UCS command the select Face option.
  • start 3DARRAY command and take care about positive and negative values since Positive values generate the array along the positive X, Y, and Z axes. Negative values generate the array along the negative X, Y, and Z axes.
  • your success depend on the values that you enter.
Good Luck..
Imad Habash
Message 3 of 8
This is Rectangular array. I want path array,
I have curves and arcs. I would like to array an object on them.
Message 4 of 8
imadHabash
in your first Post >> How to 3d path array an object with a specific slope <<  and now >> I have curves and arcs << !!!
>> This is Rectangular array. I want path array, <<  to get that try to use ARRAYPATH command.
regards,
Imad Habash
Message 5 of 8
john.vellek
Hi @Anonymous,
Can you give me more details on what you are trying to create? I suspect your issue is in drawing the path and not the array part of this.
Without any more information, I suggest using construction lines/points to assist  you in laying out your 3D curved path.
John Vellek
Message 6 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 7 of 8
Hi Mr John.Vellek
i am very Sorry For  Late Reply.
Actually I was trying to Calculate the Gradient and Camber Levels on Road.
So i was thinking that if i can path array, my points to selected Center line of road, with specific Slope, then i can get levels on 3 meters interval.
so the problem was solved in Civil 3d program
please check this post. is it possible in AutoCAD?
http://forums.autodesk.com/t5/autocad-civil-3d-forum/need-levels-on-gradient-amp-camber-on-road-3m-i...
Message 8 of 8
john.vellek
Hi @Anonymous,
This is a tricky one. While I think you can probably do this in AutoCAD it would be rather tedious. Can you attach a simple drawing that illustrates your road? If so, I will take a look for you. I suspect it might be better thought  to move this thread to the Customization forum to see if someone has a LISP routine that can do this.
John Vellek
