We use basic 3D objects and blocks to create simple pipe layouts. I have had it before where one section of pipe may print out as solid black but usually it means I have another solid on top it. I delete it and it prints out normally.
This time it is MULTIPLE sections that are coming up solid. It is always a straight piece of pipe (cylinder). Also, when I plot the isometric view it prints out normally.
I have tried making a new cylinder, using an extruded circle instead of the cylinder, different layers, different print settings and everything else I could think of. But I cannot figure it out. My only other thought is that it could be something with my PDF viewer (Adobe). Any help is appreciated!
Tried that and no luck. Thank you tho.
I actually ended up creating a new autocad file and it worked. not sure why I didnt think of that before!
