AutoCAD Forum
3D Cylinder Plots Solid Black
4 REPLIES 4
395 Views, 4 Replies
We use basic 3D objects and blocks to create simple pipe layouts. I have had it before where one section of pipe may print out as solid black but usually it means I have another solid on top it. I delete it and it prints out normally.
This time it is MULTIPLE sections that are coming up solid. It is always a straight piece of pipe (cylinder). Also, when I plot the isometric view it prints out normally.
I have tried making a new cylinder, using an extruded circle instead of the cylinder, different layers, different print settings and everything else I could think of. But I cannot figure it out. My only other thought is that it could be something with my PDF viewer (Adobe). Any help is appreciated!
Labels (2)
4 REPLIES 4
Patchy
Extrude a circle using surface instead of solid would it help?
devitg
@Anonymous Please upload your sample.dwg
in reply to: Patchy
Tried that and no luck. Thank you tho.
I actually ended up creating a new autocad file and it worked. not sure why I didnt think of that before!
tramber
You should play with DISPSILH to set to 1 and ISOLINES, that I often put to 0.
Tell us if it helps.
AutoCAD Inside the Factory
