AutoCAD Forum
2020 - preview for polygonal viewport grip editing
4 REPLIES 4
w64bit
509 Views, 4 Replies
Draw a polygonal viewport and move it by square center grip => AutoCAD does not display the moving viewport.
It's an AutoCAD bug or it's my computer?
4 REPLIES 4
natasha.l
in reply to: w64bit
Hello @w64bit
It is as designed, I tested this out for you.
  •  Selecting & using the square center grip will activate the "Stretch" command
  • You will have to select, then right-click & select "Move"
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
w64bit
in reply to: natasha.l
This is the question, why only for polygonal viewport AutoCAD activates stretch command for center grip?
neaton
in reply to: w64bit
You don't get the rubberband preview for polygonal viewports in 2018 either. I don't have earlier than that on my computer so can't verify if it was ever programmed to show the rubberband for when you move the polygonal viewports.
Nancy
natasha.l
in reply to: w64bit
Hello @w64bit
I understand that this seems inconsistent to change this for polygonal viewports, but this is as designed. Smiley Frustrated
Please feel free to provide your feedback here, where a developer can review it & take it into consideration.
Thank you.
AutoCAD Inside the Factory
