AutoCAD Forum
2019 VERSIONTOOLBAR
21 REPLIES 21
Message 1 of 22
apanbasu
592 Views, 21 Replies
2019 VERSIONTOOLBAR
There is a Toolbar that contain erase, copy, rotate, Move, Offset, etc. I could not find that tool bar.  I found 2019 version of AutoCAD for my desktop. It is easy to use that tool bar instead of opening Modify for these commands.
Can anybody help me to find that tool bar?
21 REPLIES 21
Message 2 of 22
paullimapa
in reply to: apanbasu
Do a screenshot of that toolbar and share that here
Paul Li
IT Specialist
@The Office
Message 3 of 22
paullimapa
How's about this one:
-TOOLBAR
Modify
Show
Paul Li
IT Specialist
@The Office
Message 4 of 22
pendean
CUI command
Message 5 of 22
apanbasu
in reply to: pendean
I was able to open the location but could not find what I was looking for.  I was looking exacty what you have shown.
I have attached a screen shot where I am in my effort.
Message 6 of 22
apanbasu
in reply to: paullimapa
I saw this but this is not what I am looking for
Message 7 of 22
apanbasu
I did not find the related video.
Message 8 of 22
paullimapa
unless you share a screenshot of what you're looking for all we can do is guess or provide you with what's built into autocad now
Paul Li
IT Specialist
@The Office
Message 9 of 22
cadffm
Use google to find a screenshot of what you are looking for
and share
Sebastian
Message 10 of 22
pendean
@apanbasu wrote:
...but could not find what I was looking for....
From your 2019 program's HELP, just follow along
https://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-510E8CAF-3B78-4890-BE2E-0740E98ACBC8
HTH
Message 11 of 22
apanbasu
I do not have Toolbar and that is why I cannot show in a screen shot. But if you see Pendean's post in reply of my first post - you can see the toolbar I am looking for.
Message 12 of 22
Valentin-WSP
@apanbasu ,
I think all you have to do is grab and move out from the lower left, exactly where the Red arrow is shown on your screen.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 13 of 22
apanbasu
Thank you. Thank you. It was sitting there in front of my eyes.
Thanks again
Message 14 of 22
paullimapa
Now can you do a screenshot and share with us how that Modify toolbar looks?
Paul Li
IT Specialist
@The Office
Message 15 of 22
cadffm
"But if you see Pendean's post in reply of my first post - you can see the toolbar I am looking for."
Thats the same what he showed too
incl.
the way you can turn it on.
-toolbars
Modify
enter
Or not?
Sebastian
Message 16 of 22
paullimapa
Thanks @cadffm @pendean post shows this:
My post shows this:
What's the difference @apanbasu ?
Paul Li
IT Specialist
@The Office
Message 17 of 22
apanbasu
I have attached a screen shot showing the location of the tool bars. I am used to it and that is what I was trying to get
Message 18 of 22
paullimapa
Yep that’s the standard Modify toolbar that comes shipped with AutoCAD. In your case it’s positioned vertically in 2019 and docked to the side. My posts just shows it in 2020 floating horizontally on the drawing screen.  If you accidentally closed it and want it back as I mentioned in my replies run the following commands to get it to show:
-TOOLBAR
Modify
Show
Paul Li
IT Specialist
@The Office
Message 19 of 22
apanbasu
I do not have 2020 version. Thus I will stay where I am. At this stage it
serves my purpose and I am OK with that.
Many thanks for your suggestions.
Message 20 of 22
paullimapa
Yes, definitely stay with the version that's still working. I just wanted to point out that the 2019 Toolbar version you referred to is the same as or similar to the tool bar I had posted called:  Modify
Also notice that when you enter the following commands:
Command: -TOOLBAR
Enter toolbar name or [ALL]: Modify
AutoCAD responds with the following options:
Enter an option [Show/Hide/Left/Right/Top/Bottom/Float] <Show>:
As I've already talked about what Show does, there are the additional prompts like: Float
This will cause the specified toolbar in this case the Modify toolbar to move from a docked position that may not be seen to a floating location on the drawing screen.
Now you can drag this Modify toolbar to a different docked right, left, top or bottom location on the drawing area.
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
